Home > Forums > General Forums > Structural Mechanics
ANSYS Compression only/Elastic support
Old   June 6, 2014, 09:23
Default ANSYS Compression only/Elastic support
Yavuz Hes
yavuz.hspc is on a distinguished road
I was able to simulate a structure using bodies in which compression only support was available. Since thickness is very small compared to the other dimensions of the body part, moved on working with mid-surfaces to reduce computation times. However, I have discovered that compression only support is not available in ANSYS WB (15.0) for surface bodies. Now thinking of using the available elastic support as the bottom boundary condition for the structure situated on a rigid foundation.
Common description of elastic support states imposed stiffness acts only in a direction that is normal to faces.
Is there a way to adjust this condition so that elastic support becomes effective only in compression? Or do I need to seek for another solution?
I have an option in my mind such that I will create a rigid body under the surfaces touching the ground and use fixed support on the bottom face of this rigid bodies.
Any ideas?
Thanks in advance.
yavuz.hspc is offline   Reply With Quote
compression only support, elastic support
Question How to save Ansys 13 project to be opened by ansys 12 ? rafiktharwat ANSYS 3 July 17, 2017 21:09
ANSYS 13 Multifield, mechanicaldesign CFX 2 May 26, 2012 09:32
ansys imports icem-cfd ansys mesh adam2008 ANSYS Meshing & Geometry 0 March 5, 2011 08:40
Ansys installation on VISTA 32/64 bit sol'n! Andrzej F CFX 0 September 22, 2008 16:51
ansys customer support marvin CFX 2 May 20, 2008 20:22
