Problem with meshing simplification in CATIA V5 |
December 29, 2014, 11:24 |
Gil Wéry
I am actually working on a 3d truss, I need to make a structural analysis using the GSA workbench. I can make analysis with an automatic mesh (generated by catia). But I have several load cases so in order to decrease the time of processing I would like to lighten the mesh. Here is a picture of what I would like to do : http://www.designworldonline.com/upl...f-analysis.jpg The mesh is rectangular between the two junctions but when it gets closer to the junction, it becomes triangular and smaller. How is it possible to do that? I have tried by making a little groove where I wanted to change the type of mesh but it leads to a mesh problem. In summary, how do we make a progressive (bigger to smaller elements) and shape changing (rectangular to triangular) mesh on a tube? Thank you in advance |
catia v5, mesh 3d, progressive, tube |
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 18, 2023 23:49 |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 07:21 |
[ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem | dalecooper | ANSYS Meshing & Geometry | 0 | July 19, 2013 07:04 |
[ICEM] Tetra meshing problem | Smaras | ANSYS Meshing & Geometry | 4 | February 21, 2013 09:04 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
