How can I obtain volumetric deformation on a solid material? |
March 17, 2017, 06:36 |
Onur Özcan
Rep Power: 12 |
Hi all,
I am using ANSYS 14.5 or 17.2.Anyway, I could get vectorial deformations from Static Structural. But I could not see volumetric deformations values. How can I get it? or is there any software to obtain it? Kind Regards, |
March 24, 2017, 00:30 |
Onur Özcan
Rep Power: 12 |
?? any knowledge?
April 7, 2017, 07:33 |
Gwenael H.
Rep Power: 20 |
Hi Onur,
The feature you’re looking for isn’t’ directly implemented in WB nor APDL classic. One way around is to store the volume of each element using ETABLE, once you’ve solved the static structural you can use the UPCOORD command which modifies the coordinates of the selected nodes based on displacements. Then output the updated element volume with a second ETABLE. This will give you the volume of the deformed elements. The difference of your 2 ETABLE will give you the output you need. Bests, |
How can I obtain volumetric deformation on a solid material? | oozcan | System Analysis | 1 | March 18, 2017 10:54 |
How to introduce solid material and its properties at wall? | wassli | STAR-CCM+ | 3 | February 22, 2017 16:01 |
External file as input for volumetric heat source in solid (chtMultiRegionSimpleFoam) | pbnuclex | OpenFOAM Pre-Processing | 0 | June 1, 2016 03:53 |
creating solid material for the reaction in the fluent | borhan_sd@yahoo.com | Main CFD Forum | 0 | May 20, 2013 01:51 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
