Home > Forums > General Forums > Structural Mechanics
ACP Pre error "Layered section is not allowed in the current analysis"
Old   July 12, 2018, 06:33
Unhappy ACP Pre error "Layered section is not allowed in the current analysis"
Hassan Iftekhar
hasanifte is on a distinguished road
I am working on a ansys workbench trying to run a simulation using ACP pre —-> transient thermal coupled with static structural.
The problem is a simple cylinder sheet. plys are created in acp pre. The temperature of the cylinder decreases from 120 to 20 degree celcius. Then i will link it with static structure and look for deformations in cylinder. In transient thermal it is giving the following error.
“Layered section is not allowed in the current analysis” pls see attached picture.
Please help to solve this error.
hasanifte is offline   Reply With Quote
Old   July 13, 2018, 02:07
Mrt23 is on a distinguished road
you can look videotutorials on youtube. i think it will help you to solve error.
Mrt23 is offline   Reply With Quote
Old   August 12, 2018, 14:23
Achilleas Milios
AchilleasM is on a distinguished road
Hi Hassan,
I have the same problem the last weeks! Did you find the solution?
I would really appreciate it!
Thanks in advance,
Achilleas
AchilleasM is offline   Reply With Quote
Old   August 15, 2018, 23:43
Hassan Iftekhar
"Layered thermal shells are released as Beta options. So in order to get rid of the error message, one needs to turn on beta options (Workbench >> Tools>> Options>>Appearance> Beta options) and resolve.
Old   August 19, 2018, 16:01
Achilleas Milios
Thanks a lot!
Your Cylinder sheet is modelled with shell elements? If so, were you able to plot the temperatures in every ply,or was it not part of your study?
Old   August 19, 2018, 23:43
Hassan Iftekhar
I transfered solid composite data while linking it with transient thermal. Is this what you are asking? Yes i was able to view the temperature contours.
Current density visualisation (PEM fuel cell add-on module) pchoopanya FLUENT 10 August 21, 2023 14:33
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 10:45
LiftDrag utility from v12 to v141 cfdphil OpenFOAM Running, Solving & CFD 2 December 5, 2007 05:49
