September 3, 2013, 12:55 |
SU2 2.0.6 test case execution errors
Austin Murch
I've compiled SU2 v2.0.6 from the github on Ubuntu 12.04, using Metis v5 and openMPI. I'm running Ubuntu via VirtualBox on a Windows 7 machine.
I'm running into the following errors: 1. When trying to run the /SU2-2.0.6/TestCases/euler/onearam6 test case in serial I get: ERROR: Cannot find value LU_SGS in given map. 2. When I try to run this case in parallel using "parallel_computation.py" I get: AssertionError: Config file has multiple specifications of DV_VALUE_OLD Thanks in advance! |
September 3, 2013, 16:25 |
Austin Murch
Update:
1. Caused by incorrect specification of the LINEAR_SOLVER parameter in the cfg file. Was able to fix by copying "config_template.cfg" from /SU2-2.0.6/. This problem appears throughout the TestCases configuration files. 2. Appears to be stemming from config files generated by python scripts; parameters implicated are DV_VALUE_OLD, DV_VALUE_NEW, and DV_VALUE. The python scripts seem to ignore any values for these parameters in the base config file and fail to write any values in the auto-generated config files. If I manually edit the auto-generated config files after the fact, I can get SU2_DDC and SU2_CFD to run, but this defeats the purpose of the python scripts... |
September 3, 2013, 17:09 |
Austin Murch
Grabbed a fresh copy of 2.0.6 from the github, and found all config files have the proper LINEAR_SOLVER specifications and the DV_VALUE issue resolved as well. Not sure what happened with the first copy of 2.0.6 I was working with...
October 3, 2013, 14:44 |
#4 | |
Francisco Palacios
Yep, we are reorganizing the config options for the new release. We always update the configuration_template.cfg, and those cases that are in our regression test system. Thanks for using SU2, Best Francisco |
October 4, 2013, 09:30 |
rans/rae2822 test case v2.0.8
Tom Jentink
I had the base stable version installed (v2.0) and ran a few test cases with no problems.
Last night I installed the latest from github (2.0.8) and the new testcase directory. I've been trying to run the rae2822 airfoil case (in rans directory) and it core dumps w/out any helpful information. any idea where to look for the problem? |
Large test case for running OpenFoam in parallel | fhy | OpenFOAM Running, Solving & CFD | 23 | April 6, 2019 09:55 |
Problem with plasma test case: residuals are NAN | rafpepe | SU2 | 2 | January 20, 2013 09:37 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Interfoam Droplet under shear test case | adona058 | OpenFOAM Running, Solving & CFD | 3 | May 3, 2010 18:46 |
c1 body test case | Eric Lenormand | Main CFD Forum | 0 | March 2, 2000 06:54 |
