Home > Forums > Software User Forums > SU2
Question about SU2 convergence
Old   April 6, 2014, 03:39
Question Question about SU2 convergence
zhen yi
codezy is on a distinguished road
Hello guys,
In fact, I have a big problem with SU2 now. It’s about metis and convergence. When I use mpirun to run SU2 with different -np numbers, the speedup curve is not an increasing function.
For example, when -np = 42 the TestCase runs for thousands Iters with the residual around -4. But when I run SU2 with -np=84 the Testcase exited succeed for 570 Iters, the residual around -1. Why?
Does the SU2’s kernel algorithms have different convergence speed with different metis diced?
Or may be I got the wrong way?
Thank you
codezy is offline   Reply With Quote
Old   April 8, 2014, 02:47
Thomas D. Economon
economon is on a distinguished road
While the values of the residuals may not be equivalent iteration-by-iteration for implicit, parallel calculations, the residuals should report identical values for every iteration if you choose an explicit method.
Unfortunately, it is difficult to identify some problem/mesh-dependent issues. Just to test your installation without any aggressive settings that may be causing issues, you might turn off multigrid (MGLEVEL= 0), switch to explicit time integration (TIME_DISCRE_FLOW= EULER_EXPLICIT), and turn the CFL number down (perhaps CFL= 0.5). Try running several iterations, say 10, on various numbers of processors. If you are still seeing odd behavior and the residuals don't match with each iteration, I recommend that you check your configure options & rebuild the code.
Hope this helps,
Tom
economon is offline   Reply With Quote
Old   April 8, 2014, 03:02
zhen yi
Originally Posted by economon View Post
Hope this helps,
Tom
Thank you very much, that may be help me. By the way, I wanna to compile SU2 to run it faster. Is that some best practices? Or may I use -O3/-O2 to make it better? Because if I use O3 the precision may get down.
Thank you
convergence, metis, mpi, su2
Time step dependence of convergence behavior of steady state simulations in CFX Chander Main CFD Forum 5 December 23, 2013 05:31
Convergence Question racerdude777 Main CFD Forum 2 March 14, 2011 22:07
Convergence Question James FLUENT 2 October 29, 2005 14:59
Question about convergence criteria? Thomas FLUENT 7 April 8, 2005 19:38
help! cyclone convergence question Lcw FLUENT 1 January 26, 2005 15:29
