Home > Forums > Software User Forums > SU2
Unable to use shape_optimization.py for tutorial unsteady problem when adding constra
Old   July 11, 2022, 11:08
Default Unable to use shape_optimization.py for tutorial unsteady problem when adding constra
Qiulin
qren3 is on a distinguished road
When I use shape_optimization.py to optimize an airfoil in the tutorials, I cannot put thickness or area as constrants due to this error:
Traceback (most recent call last):
File "/.../shape_optimization.py", line 183, in <module>
main()
File "/.../shape_optimization.py", line 92, in main
shape_optimization( options.filename ,
File "/.../shape_optimization.py", line 110, in shape_optimization
config = SU2.io.Config(filename)
File "/.../SU2/io/config.py", line 123, in __init__
tavg_keyGroup = "TAVG_" + historyOutFields[key_inner]["GROUP"]
KeyError: 'AIRFOIL_THICKNESS'
However, adding the constraint of lift or drag can work well.
But the area and thickness can be found in config_template.
How can I solve this problem? Thank you very much.
qren3 is offline   Reply With Quote
su2 adjoint
chtMultiRegionSimpleFoam 3D problem Lucie OpenFOAM Pre-Processing 2 June 21, 2016 05:23
2D unsteady convection problem xces FLUENT 0 June 6, 2014 16:10
unsteady heat transfer model problem Beryl FLUENT 0 July 12, 2011 23:26
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
Unsteady Boundary Layer Problem C.J.Yoon Main CFD Forum 0 January 27, 2006 04:19
