SU2 installation succesful but failure when running |
October 21, 2015, 04:38 |
Rep Power: 12 |
Hi everyone,
I've installed SU2--master in server, there is no problem in the installation. When I run Quick Start cases I got this errors : A requested component was not found, or was unable to be opened. This means that this component is either not installed or is unable to be used on your system (e.g., sometimes this means that shared libraries that the component requires are unable to be found/loaded). Note that Open MPI stopped checking at the first component that it did not find. Host: server Framework: crs Component: none -------------------------------------------------------------------------- [server:24496] *** Process received signal *** [server:24496] Signal: Segmentation fault (11) [server:24496] Signal code: Address not mapped (1) [server:24496] Failing at address: 0x28 [server:24496] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0xf0a0) [0x7fcd04d710a0] [server:24496] [ 1] /usr/lib/libopen-pal.so.0(mca_base_select+0x106) [0x7fcd05d5f356] [server:24496] [ 2] /usr/lib/libopen-pal.so.0(opal_crs_base_select+0x7e) [0x7fcd05d7159e] [server:24496] [ 3] /usr/lib/libopen-pal.so.0(opal_cr_init+0x303) [0x7fcd05d50293] [server:24496] [ 4] /usr/lib/libopen-pal.so.0(opal_init+0x17b) [0x7fcd05d4fc0b] [server:24496] [ 5] /usr/lib/libopen-rte.so.0(orte_init+0x4f) [0x7fcd05fa1b3f] [server:24496] [ 6] /usr/lib/libmpi.so.0(+0x38374) [0x7fcd06219374] [server:24496] [ 7] /usr/lib/libmpi.so.0(MPI_Init+0x16b) [0x7fcd0623a01b] [server:24496] [ 8] SU2_CFD(main+0x58) [0x4b7768] [server:24496] [ 9] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xfd) [0x7fcd049f5ead] [server:24496] [10] SU2_CFD() [0x4b985d] [server:24496] *** End of error message *** Segmentation fault Regards, Ridwan |
October 22, 2015, 11:29 |
Tim Albring
Rep Power: 10 |
Hi rfadlika,
can you give me some information ? - operating system - SU2 version - configure options - command that you used to run the case - the complete output of SU2_CFD Thanks ! |
October 23, 2015, 02:45 |
#3 | |
Rep Power: 12 |
OS: Linux Mint 17.1 SU2 version (I do not know the version, but it is not educational version and I get from github SU2-master) Configure options is according to the tutorial Quick Start Command : SU2_CFD filename.cfg There is no output yet The Installation type is 'Parallel and CGNS' Thanks |
November 2, 2015, 18:42 |
Mesut Ozil
Rep Power: 10 |
Hey Ridwan,
I would suggest you to reinstall Su2 but before that make sure you use make clean for cleaning previous file and this time before installing it make a note that you have all the prerequisite like g++(updated lib) and if you are trying for parallel make sure you have installed MPICH correctly as sometime it may give an error!! Best Ozil!! |
[OpenFOAM] could not open file .vtk in paraview | ali_atrian | ParaView | 8 | August 27, 2014 10:31 |
Problem running in parralel | Val | OpenFOAM Running, Solving & CFD | 1 | June 12, 2014 02:47 |
There is a catastropic failure in SU2 3.0.1 | codezy | SU2 | 1 | April 13, 2014 18:42 |
SU2 3.0 build failure | waku2005 | SU2 Installation | 4 | January 24, 2014 12:40 |
Official release of SU2 V3.0 and SU2 Educational V1.0 | fpalacios | SU2 News & Announcements | 2 | January 22, 2014 05:28 |
