Home > Forums > Software User Forums > SU2
Urgent - Perform an DISCRETE adjoint analysis in parallel_computation
Old   April 15, 2018, 12:12
Question Urgent - Perform an DISCRETE adjoint analysis in parallel_computation
João Lourenço
JPBLourenco is on a distinguished road
Hello everyone,
I'm with some problems in performing a Discrete Adjoint analysis in parallel computation using the solution_flow file from the direct analysis to the flow. I'm doing the some proceeder like in CONTINUOUS Adjoint analysis. In CONTINUOUS adjoint I'm doing the next steps:
1- Run the mesh.su2 and the NACA_0012.cfg file with:
MATH_PROBLEM= DIRECT
RESTART_SOL= NO
terminal: parallel_computation.py -f NACA_0012.cfg -n 8
2- Change the name of restart_flow.dat to solution_flow.dat
3- Change in the NACA_0012.cfg file
MATH_PROBLEM= CONTINUOUS_ADJOINT
RESTART_SOL= NO
4- Run the mesh.su2, NACA_0012.cfg and solution_flow.dat file.
in the terminal the parallel analysis identify the solution_flow.dat and mesh.su2 to performed the adjoint analysis.
For the DISCRETE adjoint analysis I follow the same steps but, in the terminal, appears only identified the mesh file and says "No restart solution, use the values at infinity (freestream).".
How can I perform an DISCRETE_ADJOINT analysis in parallel with the solution_flow.dat file?
My goal is to do an shape optimization with the solution_flow.dat and the solution_adj.dat file.
Thanks to everyone that help me
JPBLourenco is offline   Reply With Quote
Old   April 23, 2018, 10:38
Tim Albring
talbring is on a distinguished road
Just follow exactly the same steps, but with MATH_PROBLEM=DISCRETE_ADJOINT instead of MATH_PROBLEM=CONTINUOUS_ADJOINT.
Or just execute the discrete_adjoint.py script.
Tim
Developer Director @ SU2 Foundation
Get involved:
talbring is offline   Reply With Quote
Problems launching adjoint max_ SU2 2 March 12, 2016 11:32
hard to convergent with SU2 4.0 for Euler adjoint Xianguu SU2 1 July 14, 2015 17:09
Flow analysis in a Convergent-Divergent Nozzle (URGENT!) hasan_hzl ANSYS 2 June 30, 2009 00:46
Urgent help needed with dpm analysis Esosa FLUENT 0 June 12, 2009 05:06
Problem about multi-phase analysis (Urgent) Prof. Lau (PolyU) CFX 2 February 9, 2007 17:59
