Home > Forums > Software User Forums > SU2
Can a mesh be too refined for SU2?
Old   June 18, 2018, 13:10
Default Can a mesh be too refined for SU2?
perseo is on a distinguished road
Hi!
First of all I'll introduce miself, I'm an aeronautics student and I'm doing a research about actuation in the boundary layer. I'm using SU2 to implement the actuation model. I'm validating some results against Fluent for some cases.
The problem is the following: I'm simulating a low speed 2D NS incompressible simulation with turbulence (SA model). I have a very refined mesh with around 6000 elements covering the airfoild (and around 200k in total). A partner of mine has done the simulation with ansys and obtains reasonable results. On the other hand I obtain a stepped Cp profile after converging to a residual of ^-8 with Su2.
Have any of you experienced a similar problem?
Thank you in advanced,
Javi
[img]https://imgur.com/2kmWM5i[\img]
This image is my result for 0 angle of attack and 10 meters per second.
perseo is offline   Reply With Quote
Old   June 19, 2018, 08:07
CarlosLozano is on a distinguished road
I wonder how did you generate such fine mesh? Was it by refining previous meshes? This is important since unless the mesh refinement algorithm incorporates some kind of correction to account for the real geometry (which, I think, SU2 doesn't have), the new nodes are aligned with old ones and do not quite follow the real geometry (i enclose two examples, one without geometry correction, another with geometry correction; adapted meshes are depicted in red in both cases). This can cause oscillations in the cp, especially near suction peak past the leading edge.
Hope this helps
CarlosLozano is offline   Reply With Quote
Old   June 19, 2018, 11:51
Hi and thanks for the answer!
The mesh was generated with ANSYS by my partner (who is working with FLUENT kind in paralel to my work in SU2) and exported to .cgns format. I don't know what procedure did she follow to generate it but I guess it was just a single run with very fine sizing at the surface of the airfoil and an inflation basically.
Javi
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[snappyHexMesh] snappyHexMesh & Mesh around a missile sasanghomi OpenFOAM Meshing & Mesh Conversion 2 October 15, 2014 19:54
How to Refined mesh ? madhuri STAR-CCM+ 2 January 21, 2011 19:37
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
