November 8, 2018, 17:49 |
better tecplot output?
Tom Jentink
Trying to output a tecplot solution. There's no way to separate out the boundary surfaces. ie, wall, inflow, outflow are not zones in my tecplot file. Is there a direct cgns output option?
November 16, 2018, 21:39 |
Heather Kline
Please take a look at the surface_flow.dat output file, to see if that works for you - this will contain the information on the boundaries specified by the MARKER_PLOTTING option.
An ad-hoc solution to have the boundaries in separate zones would be to repeatedly run SU2_SOL with config files that have different values in MARKER_PLOTTING and SURFACE_FLOW_FILENAME, making sure to also specify the correct solution files. Those files could then be loaded to a single tecplot layout. |
[swak4Foam] outputTime in Swak function | immortality | OpenFOAM Community Contributions | 20 | October 6, 2022 12:08 |
Su2 V5.0.0 developer branch sliding interface feature: Tecplot output file problem | JyothiKumar | SU2 | 1 | August 11, 2017 09:23 |
writing execFlowFunctionObjects | immortality | OpenFOAM Post-Processing | 30 | September 15, 2013 06:16 |
Tecplot output format in 2-D cartesian grid | jinwon park | Tecplot | 5 | April 7, 2008 06:28 |
Output data from STAR-CD to Tecplot | Lee | Siemens | 0 | June 5, 2006 12:58 |
