Home > Forums > Software User Forums > SU2
SU2 crashes while generating output files
Like Tree1Likes
  • 1 Post By BenP
Old   August 13, 2019, 10:56
Default SU2 crashes while generating output files
BenP is on a distinguished road
Hello, I have a problem where SU2 crashes when generating output files. There is no error message, the simulation just stops. I've attached a screenshot of the command prompt output I get as well as my .cfg file.
I suspect the problem originates from the mesh I am using (generated with gmsh), but if there was something wrong then would SU2 not crash before ever needing to write any output files? Or at least there would be something visibly wrong with the outputs at each iteration?
From setting the WRT_SOL_FREQ option to effectively remove any periodic output generation, I can see that the solution does converge properly, but then crashes on convergence.
The .su2 file I am using can be accessed using this link (it's fairly large so I couldn't directly upload it). https://1drv.ms/u/s!An1_lpfAG0BCg5VQ...WAtyA?e=9T3g85
I am running SU2 6.0.0 in serial on Windows 10.
Does anyone know why SU2 would operate seemingly as it should but only crash when writing the outputs?
Any help is greatly appreciated
BenP is offline   Reply With Quote
Old   August 19, 2019, 00:48
Default Same issue of SU2 crashing before writing output files
Dr. H.K. Narahari
hk.narahari is on a distinguished road
I have been having the same trouble ( as reported a few days back). The code runs OK ( 100 or 1 iteration) but crashes before writing out the files. I too had created the grid in GMSH for 3 different geometries with same issue, hope it gives a clue to the cause of the problem.
Thanks in advance
Narahari
hk.narahari is offline   Reply With Quote
Old   August 19, 2019, 10:53
Default Fixed
I managed to find a solution that works for me.
My understanding is that GMSH will automatically duplicate surfaces that need re-orientated after using any of the Boolean commands available with the OpenCascade kernel (I used a lot of these to create the geometry I was using).
My mistake was setting GMSH to "save all elements" when exporting the SU2 mesh, which would inadvertently save the duplicated surfaces as well and subsequently cause SU2 to crash when trying to generate outputs.
By default, GMSH will create an SU2 mesh by only exporting elements that have been assigned to a physical entity.
While I had assigned all the necessary "Physical Surfaces", I hadn't assigned a "Physical Volume" to the main control volume. Once doing this and making sure to leave the "save all elements" box unchecked, gmsh no longer exported the duplicated surfaces and I could run SU2 without any problem.
Hope this helps in some way.
hk.narahari likes this.
Old   August 21, 2019, 03:24
Dr. H.K. Narahari
I tried your suggestion for a couple of cases and it worked . Thanks a lot, I was really stuck because of that bug.
Regards
Narahari
Problems generating xy files after executing foamLog arieljeds OpenFOAM Post-Processing 2 October 15, 2023 11:06
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 05:53
SU2 Turbulent Simulation flow output Indu Kant Deo SU2 2 October 16, 2021 09:14
SU2 basics - displaying output and ending a run kmiller SU2 3 August 25, 2018 19:00
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
