Home > Forums > Software User Forums > SU2
Spalart Allmaras Gamma Re Theta Model
Old   May 9, 2013, 14:14
Question Spalart Allmaras Gamma Re Theta Model
taxalian is on a distinguished road
Send a message via Skype™ to taxalian
Hi SU2 Users,
I have tried to compute the NREL S-series wind turbine airfoil s809 test case available in SU2 v2.0.3 developers release.
The transition model implemented seems to be the γ−Reθt−SA model, introduced by Medida et al.
The problem is that the simulation diverges everytime few iterations and the residual of SA-eddy viscosity results in nan.
I tried to adjust the intermittency factor and the freestream turbulence intensity but does not help at all. I think this should not be the case normally at AoA=0°.
May be the model is not yet implemented completely or i don't what other issues causes the simulation not to converge.
May be it's also a good idea if we can have an input parameter that defines the freestream viscosity ratio i.e. mu_turb / mu_lam
Waiting for your reply.
Thanks in advance.
taxalian is offline   Reply With Quote
Old   May 14, 2013, 13:36
aniketaranake is on a distinguished road
Dear Taxalian,
The transition model is not yet fully implemented and is not ready for use. Sorry for the inconvenience.
Regards,
Aniket
aniketaranake is offline   Reply With Quote
Old   May 14, 2013, 14:58
Hi Aniket,
Thanks for the reply and info. Hope this will be available in the SU2 regular version release.
Old   October 4, 2013, 04:45
Default γ−Reθt−SA/SST turbulence model
Is the γ−Reθt−SA/SST turbulence model available in github is in fully functional mode now. I tried to run again the similar test case mentioned earlier in this thread, but no success. The code just stopped after performing Mulitgrid agglomeration.
Old   December 14, 2020, 04:45
Jose Daniel
jdp810 is on a distinguished road
Sorry for resurrecting this thread, but are there any news about the implementation of this transition model?
Thank you
jdp810 is offline   Reply With Quote
Gamma - ReTheta Transition Model badger1 STAR-CCM+ 0 February 10, 2013 09:34
Transition Model - Gamma Re Theta nomad STAR-CCM+ 5 April 17, 2011 08:34
spalart allmaras-turbulence model Usman FLUENT 1 February 24, 2009 16:50
Spalart Allmaras Wall Function vandraren OpenFOAM Running, Solving & CFD 3 February 8, 2008 08:42
High Re Spalart Allmaras jj Siemens 0 October 3, 2005 15:31
