March 24, 2021, 08:30 |
MESH ADAPTATION in SU2 V7.1.1
Ashvin
Rep Power: 6 |
Has anyone been able to use the mesh adaptation options in V7.1.1? In the config template file there are options: % ------------------------- GRID ADAPTATION STRATEGY --------------------------% % % Kind of grid adaptation (NONE, PERIODIC, FULL, FULL_FLOW, GRAD_FLOW, % FULL_ADJOINT, GRAD_ADJOINT, GRAD_FLOW_ADJ, ROBUST, % FULL_LINEAR, COMPUTABLE, COMPUTABLE_ROBUST, % REMAINING, WAKE, SMOOTHING, SUPERSONIC_SHOCK) KIND_ADAPT= FULL_FLOW % % Percentage of new elements (% of the original number of elements) NEW_ELEMS= 5 % % Scale factor for the dual volume DUALVOL_POWER= 0.5 % % Adapt the boundary elements (NO, YES) ADAPT_BOUNDARY= YES Can we use these options to adapt the mesh in the vicinity of a shock? Thanks Ashvin |
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) | Combas | SU2 | 44 | March 12, 2024 00:35 |
Mesh Adaptation in SU2. What to do with generated files? | 7amim | SU2 | 1 | July 23, 2018 01:39 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Axisymmetric 2D mesh adaptation - ERROR | Pepe | CFX | 3 | May 30, 2011 08:28 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
