Home > Forums > Software User Forums > SU2
Questions regarding Discrete Adjoint Solver
Like Tree1Likes
  • 1 Post By Sprotte
Old   April 19, 2021, 10:21
Default Questions regarding Discrete Adjoint Solver
Daaman is on a distinguished road
I tried simulating the Test case of Onera M6 using the SU2's discrete adjoint solver. I am new to the implementation of the sensitivity solver and trying to analyze the results generated from the implementation, and have the following questions-
1. What is the difference between the Surface_Sensitivity contours generated by surface_adjoint.szplt and surface_sens.szplt? Which ones are usually used for representing the sensitivity of the objective function wrt to design variables?
2. What does FINDIFF_STEP in of_grad_cd.csv represent?
I'm using v 7.1.1. I have attached the config file and gradient results as well.
I appreciate any inputs! Thanks!
Daaman is offline   Reply With Quote
Old   April 24, 2021, 05:25
Ole Burghardt
Sprotte is on a distinguished road
The first is the adjoint solution (from which sensitivities are derived, it's the objective function sensitivity w.r.t. flow solution), the latter is the objective function sensitivity w.r.t. surface mesh coordinates including mesh deformation, i.e. surface mesh coordinates as design variables.
FINDIFF is used for finite differences, adjoints don't use it.
Best, Ole
Daaman likes this.
Sprotte is offline   Reply With Quote
Discrete adjoint - Derivatives of the target function w.r.t. boundary conditions CFDEng1234 SU2 2 February 19, 2020 10:39
SU2 Discrete Adjoint Error!!!! vishu343 SU2 4 October 15, 2019 18:55
Discrete adjoint for multi-zone problems pgdelaserna SU2 0 September 18, 2019 04:44
Problems launching adjoint max_ SU2 2 March 12, 2016 11:32
hard to convergent with SU2 4.0 for Euler adjoint Xianguu SU2 1 July 14, 2015 17:09
