Continuous Adjoint computation with two separate walls |
November 2, 2022, 07:05 |
Rep Power: 8 |
I am reproducing the nozzle test case but with inviscid flow and the complete nozzle geometry (i.e., adding also a lower wall). I have two separate markers for the upper and lower walls (UWALL and DWALL, resp), and when I compute the drag adjoint solution it only obeys the adj bc (psi2,psi3).(nx,ny) = (cos aoa,sin aoa).(nx,ny) on the upper wall. On the lower wall it obeys (psi2,psi3).(nx,ny) =0. I am using v5 (yes, I know....). Any clues? In the .su2 file I have . . . NMARK= 4 MARKER_TAG= DWALL MARKER_ELEMS= 943 3 0 1 3 1 2 . . . 3 941 942 3 942 943 MARKER_TAG= OUTFLOW MARKER_ELEMS= 200 3 943 1887 3 1887 2831 . . . 3 187855 188799 3 188799 189743 MARKER_TAG= UWALL MARKER_ELEMS= 943 3 189743 189742 3 189742 189741 . . . 3 188802 188801 3 188801 188800 MARKER_TAG= INFLOW MARKER_ELEMS= 200 3 188800 187856 3 187856 186912 . . . In the .cfg file I have % ---------------- BOUNDARY CONDITION DEFINITION -------------------% % % Marker of the Euler boundary (0 = no marker) MARKER_EULER= ( UWALL, DWALL ) % % Marker of the far field (0 = no marker) MARKER_FAR= ( INFLOW,OUTFLOW ) % % Marker of the surface which is going to be plotted or designed MARKER_PLOTTING= ( UWALL, DWALL ) % % Marker of the surface where the functional (Cd, Cl, etc.) will be evaluated MARKER_MONITORING= ( UWALL, DWALL ) % (Yes, I am using far-field type inlt/outlet since in v5 inflow and outflow for adjoint are not defined). Shouldn't make much of a difference for the problem at hand). Thanks in advance! |
November 2, 2022, 07:48 |
bigfoot
Rep Power: 17 |
November 2, 2022, 07:54 |
Rep Power: 8 |
Short answer: the cluster i work with has a very old SO version and v6 and higher do not compile properly. I am not the admin, so there's little i can do. Besides, v5 works fine for me and i am not sure that v6 and higher have brought much improvement for the continuous adjoint solver.
November 2, 2022, 08:23 |
bigfoot
Rep Power: 17 |
It will be impossible to help you with this. I think it is better if you try to recompile the latest su2, and we can then support you with the compilation difficulties. When the problem with continuous adjoints that you are now reporting still exists, we can then dive into the latest code and try to fix it.
Also note that system admins are there to make sure that the cluster is working properly for its users. |
November 2, 2022, 08:29 |
#5 | |
Rep Power: 8 |
Ok, thanks |
Continuous Adjoint - Linear solver diverged | pedropcb13 | SU2 | 0 | August 6, 2021 17:34 |
Discrete Adjoint Euler Computation | doan.nak | SU2 | 2 | June 6, 2014 04:01 |
Inaccurate gradient results from continuous Adjoint method | Yminjo | SU2 | 1 | January 11, 2014 22:08 |
adjoint method- uniformity | Envolly | OpenFOAM Programming & Development | 8 | July 9, 2013 01:29 |
Question about Continuous Adjoint Method | fumiya | Main CFD Forum | 6 | November 1, 2011 10:09 |
