Home > Forums > General Forums > System Analysis
Heat exchange model for a beehive
Prev Previous Post   Next Post Next
Old   November 2, 2018, 00:40
Default Heat exchange model for a beehive
Mielmari
Mielmari is on a distinguished road
I am trying to specify a model of heat exchange inside a bee hive.
- Background: bees are attacked by a mite called varroa, which kills the colony for a couple of years. That is why it is necessary to treat with chemicals every year. There are studies that show that a rise in temperature inside the hive from 35ºC (which is normal) to 42ºC kills the varroas, without harming the bees.
- My project: I am a biologist, I have computer or electronic knowledge. I want to specify a model of hot air circulation to get that rise for an hour, more or less.
- Enclosure: the enclosure (46.5x38x31cm) is filled with 10 parallel sheets (wax combs) about 27mm wide, and free spaces between them of 10mm
- Heat source: I will use two heat sources based on PTC + fan of 100W 12V each, with two temperature controllers adjusted to 42ºC
- Doubts: what is good for me: insert hot air from below and extract from above, or vice versa?
I appreciate any help
Mielmari is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
