Home > Forums > Visualization & Post-Processing Software > Tecplot
velocity field using tecplot only for one plane
Old   June 7, 2018, 02:41
Default velocity field using tecplot only for one plane
Mohammmad ali gheidi shahran
Mohammad1994 is on a distinguished road
Hello all engineers,
i want to ask you, how to export the results of one plane ( it could be the velocity field or pressure distribution etc) of a 3D simulation from the fluent solver to tecplot. when i write the data ( save cas& data in fluent) and import it to tecplot ,the 3D sketch is shown ....
i can not stand it please help me ASAP....
THANK YOU ALL
Mohammad1994 is offline   Reply With Quote
Old   June 18, 2018, 19:11
Scott Fowler
wsfowler is on a distinguished road
In Tecplot 360 you should be able to add a Slice - available on the left side of the user interface. On the slice you can display vectors or color by a scalar such as pressure.
wsfowler is offline   Reply With Quote
Old   July 11, 2018, 04:27
thank you very much
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Same pressure gradient but different velocity field TurbJet Main CFD Forum 22 April 28, 2018 03:35
potential flows, helmholtz decomposition and other stuffs pigna Main CFD Forum 1 October 26, 2017 08:34
Compute mean velocity field and mean pressure field in runtime Eman. OpenFOAM 5 February 21, 2017 12:23
