Home > Forums > Visualization & Post-Processing Software > Tecplot
wall shear stress in tecplot
Like Tree2Likes
  • 1 Post By 1988
  • 1 Post By 1988
Old   April 21, 2014, 01:01
Default wall shear stress in tecplot
Ali reza
1988 is on a distinguished road
hello everyone
I want too see wall shear stress contours in tecplot.I have got the answers from openfoam and I have calculated wall shear stresses in openfoam so I expect to be able to see these contours when I load data from openfoam however I cant find any tab or menu which shows wall shear stressed that also have read from openfoam.
is there any idea?
navid.a likes this.
1988 is offline   Reply With Quote
Old   September 9, 2016, 03:40
Charles K.
McCharles is on a distinguished road
Hello 1988,
I know this post is old but I have exactly the same problem. Did you solve your problem and if yes, do you remember how?
Maybe someone else faced this problem too.
Cheers!
McCharles is offline   Reply With Quote
Old   September 13, 2016, 07:09
Ali reza
Originally Posted by McCharles View Post
Hello 1988,
Cheers!
Hi
you should add a code like this to your 0 folder (based on your BCs)
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      wallShearStress;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    outlet
        type            calculated;
        value           uniform (0 0 0);
    inlet
        type            calculated;
    defaultFaces
        type            calculated;
and then after running the code and having results, write this commend in terminal:
wallShearStress
then it starts to calculate the wss and then when it is imported to tecplot it will have different name (for example enthalpy or etc) try to find them in the contour tab.
+you will have three WSS in tecplot for each direction and by adding this formula you can calculate WSS magnitude (Go to Data > Alter > Specify Equations and enter the following equation:
{WSS Magnitude} = sqrt({WSSx}**2+{WSSy}**2+{WSSz}**2)
Best
Papes likes this.
Old   September 13, 2016, 07:14
Charles K.
Hello 1988,
thanks for your reply. Unfortunately, I already concluded my calculations. I used the command "wallShearStress" to postprocess the WSS in OpenFoam. Now I have a new file for each time step containing the calculated wall shear stresses, but Tecplot isn't able to regognize them... Is there no other way to import the WSS in tecplot afterwards?
Old   September 13, 2016, 07:30
Ali reza
Hello 1988,
As far as I remeber it was possible to calculate averaged WSS based on a time dependent results. I mean it is possible to again add a function to tecplot to calculate averaged wall shear stress for a range of time steps.
hah I found averaged WSS contours by paraView (it was easy) as I had not found any way in tecplot to calculate these aounts.
Old   September 15, 2016, 02:33
Charles K.
Yes, I did it in paraView too by choosing wallShearStress in the Variables-List and the desired surface.
Old   September 17, 2016, 08:55
Question
navid
navid.a is on a distinguished road
Originally Posted by 1988 View Post
hello everyone
is there any idea?
i did this and now i want to plot time-average wss based on axial positin on a curved tube
do you know how can i define the axial of a curved tube as the x ?
یعنی محور وای بشه مقادیر تنش برشی و محور ایکس بشه محور لوله خمیده
navid.a is offline   Reply With Quote
Old   September 23, 2016, 03:52
Ali reza
Hi Navid
watch this:
https://www.youtube.com/watch?v=9ckpOcNmk1w
best
Old   May 6, 2021, 15:53
Burcu Ramazanlı
burcuramazanli is on a distinguished road
Hello 1988,
I have a problem regarding the WSS conversion from OpenFOAM to Tecplot. Actually, I can obtain WSS results but when I convert the results to Tecplot, then WSS values are seen to be zero, although they are not. I don't know how to resolve that issue, could you please help me if you have any idea?
burcuramazanli is offline   Reply With Quote
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
determining wall shear stress at selected point suryawanshi_nitin OpenFOAM 2 June 22, 2012 04:27
Wall Shear Stress GamFlu FLUENT 0 June 11, 2011 03:52
relationship between wall shear stress and TKE winter FLUENT 0 December 11, 2007 17:11
Re: About wall shear stress Mike FLUENT 9 November 17, 2003 14:41
