Home > Forums > Visualization & Post-Processing Software > Tecplot
Streamlines colored by velocity contours
Like Tree1Likes
  • 1 Post By Andrea1984
Old   November 28, 2013, 11:45
Default Streamlines colored by velocity contours
Andrea
Andrea1984 is on a distinguished road
This is probably a very trivial question but I am not able to figure it out by myself...how to create streamlines and color them by velocity contour values in Tecplot?
thank you
Andrea
Andrea1984 is offline   Reply With Quote
Old   December 2, 2013, 18:45
Scott Rumage
scott_rumage is on a distinguished road
Perhaps the "trick" that you are not aware of is that the streamlines or streamtraces must have a volume before one can contour them.
So in the Streamtraces menu on the "Position" tab select "Volume Ribbon" or "Volume Rod" (and not "Volume Line"), and then in the "Rod/Ribbon" tab check "Show Contour Flood" and the variable that you want to flood by, i.e. velocity.
Scott
scott_rumage is offline   Reply With Quote
Old   December 3, 2013, 05:53
Andrea
Hi Scott,
thank you for your reply.
I have just solved the problem in another way:
Under "Streamtrace Details" -> Line -> Line Color select Multi 1 in the bottom left corner of the window and it will color the streamlines with the selected contour variable.
Andrea
Sibylle likes this.
Old   December 30, 2022, 08:20
Smile nice
mahdif
mahdi fa is on a distinguished road
Originally Posted by Andrea1984 View Post
Hi Scott,
Andrea
Thanks. it helped me a lot.
mahdi fa is offline   Reply With Quote
Fluent velocity magnitude contours Al-Hashimi FLUENT 12 August 19, 2018 13:57
velocity streamlines cut at the interface! Tarantino FLUENT 0 April 11, 2013 05:27
Plotting velocity and direction contours bhavin1986 Main CFD Forum 2 April 29, 2011 16:58
tecplot 3D velocity contours inside a channel vetnav Tecplot 4 July 14, 2010 20:03
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
