Home > Forums > Mesh Generation & Pre-Processing Software > ANSA
Table Script
Like Tree2Likes
  • 2 Post By rmaries
Old   March 7, 2018, 12:04
Default Table Script
no_name18 is on a distinguished road
In NASTRAN, to define a stiffness(frequency) dependency, i often use a TABLED1 card entity. I'm currently working on a script and one of the functions needs to access data from a TABLED1 dialog box.
In the following example, how do i access the data in column 2 row 1?
Thank you!!
no_name18 is offline   Reply With Quote
Old   March 8, 2018, 02:53
Default Script to solve it.
Maries
rmaries is on a distinguished road
I got this idea from user script in ansa folder called AbaqustoDynaCurves.py
Hope it will solve your problem.
import os
import ansa
from ansa import base
from ansa import constants
deck = constants.NASTRAN
def main():
	tables = base.GetEntity(deck, "TABLED", 1)
	curve_data = base.GetLoadCurveData(tables)
	print(curve_data[0][1])
if __name__ == '__main__':
	main()
MRAJALIN and Mrt23 like this.
rmaries is offline   Reply With Quote
Old   March 8, 2018, 03:11
Thank you! It worked
script, table
[Workbench] Run ICEM Script in Workbench Script MIZOR ANSYS Meshing & Geometry 9 April 4, 2018 07:45
Problem in3D model processing mebinitap OpenFOAM 2 December 12, 2014 04:40
Installing OpenFoam on windows 7-64 Dadou OpenFOAM Installation 10 February 11, 2014 16:20
Table script problem Scibor Siemens 0 April 30, 2007 05:10
Table Manipulation furkan Siemens 0 April 4, 2006 10:23
