[GAMBIT] Need help in modeling and meshing air flow over a tree |
December 18, 2012, 02:30 |
Cheech Lim
I am very new to CFD and meshing technique. I am doing a project to simulate air flow through a tree to obtain pressure coefficient. The tree could be represented and modeled as cylinders joint together(trunk and branch). Since I am very new, I have tested with simple object like sphere. But I encountered problem in meshing a cylinder in the 3D air space. Could you please advise me on how to model and mesh a 3D grounded cylinder (like a tree) in the air space. The meshing methodology seems to be totally different and I have no idea how to start.
*I have both Gambit, and ANSYS DesignModeler and Meshing. Simulation software: Fluent. Thank you. |
December 19, 2012, 03:43 |
Maxime Perelli
Rep Power: 41 |
*Create your body (sphere, cylinder or whatever)
*Create the box which will represent your outer domain *Substract box with the body Now your domain is hollowed (your body is represented with a surface, and this is the only entity which is in contact with your fluid)
In memory of my friend Hervé: CFD engineer & freerider |
Ansys Fluent UDF - for Data Center Air flow management | kedarjan | Fluent UDF and Scheme Programming | 13 | November 13, 2013 04:20 |
Need help in modeling flow through orifice | kunal | Main CFD Forum | 0 | April 16, 2010 09:12 |
Spiral pipe modeling and meshing | Adi | FLUENT | 0 | August 1, 2008 00:39 |
Modeling and meshing wheels' contact patches | Modeling and meshing wheels' contact patches | FLUENT | 0 | December 23, 2005 07:32 |
PhD in turbulence | Hans | Main CFD Forum | 14 | October 8, 2001 03:03 |
