[DesignModeler] Boolean Error
Old   March 8, 2013, 11:09
Default Boolean Error
Joao Correia
Monstrobolaxa is on a distinguished road
I've starting learning this week how to work with Ansys Workbench and have been following a few tutorials.
I've imported an assembly from CATIA made by 2 parts. These were made as solids in CATIA.
I've imported them, created the enclosure but when performing the boolean operation to get the fluid domain and I get an error (red circle with white question mark)
Any ideas?
Monstrobolaxa is offline   Reply With Quote
Old   March 8, 2013, 11:29
Joao Correia
Further to my previous post. I've isolated the problem to one of the geometries. Doing the boolean operation with the fluid volume - body it works fine. It's only when I try to subtract the wing (attached image) from the fluid volume.
Any ideas?
Old   March 8, 2013, 12:43
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
are they solid or surfaces ???
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   March 8, 2013, 12:59
Joao Correia
It was designed as a solid. And should be a solid, unless during the import it changed something. But I imported 2 geometries in the assembly (both solids) and the other one (not shown) is fine.
Old   March 8, 2013, 13:13
diamondx's Avatar
Ghazlani M. Ali
what error do you get
Regards,
Ali
Old   March 8, 2013, 13:21
Joao Correia
Error: Boolean Operation Failed
Context: Geometry Engine, while generating Feature Boolean1
In the meantime I'll recheck the geometry in catia to see if I missed anything.
It has been designed a while ago and has been in the wind tunnel for 2 years, I simply just cleaned the geometry in catia last night. it's easier for me to do it there than in modeler!
Old   March 8, 2013, 15:07
Joao Correia
So here's an interesting one...if I create the flow volume using Primitives - Box, the boolean operation works perfectly. It's just the enclosure that doesn't work.
Any ideas?
Old   April 4, 2014, 15:00
Rush
rushupwards is on a distinguished road
I am also getting this error. Can you guys help me. I am doing the boolean operation for surface. I have attached screenshot of my geometry.
In this one part is imported as .igs & added as Frozen operation. The other part is constructed over this part in Designmodeler itself.
It would great if you guys help me.
Thanks
Rushabh
rushupwards is offline   Reply With Quote
Old   July 26, 2014, 23:48
jack robs
sa_m is on a distinguished road
Thanks
Rushabh
hi rushabh
u must convert surfaces to solid.
sa_m is offline   Reply With Quote
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 15:46
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
