[ANSYS Meshing] How to mesh my 3D geometries correctly
Old   June 3, 2014, 01:04
Default How to mesh my 3D geometries correctly
CR-7
Heat Pipe is on a distinguished road
Hello
Regarding to my concentric and eccentric . I have read and downloaded many papers and tutorials about and my knowledge now is better. but have some specific quires:
1- What is the advantage from drawing sub volumes and 4-planes .
2- Periodic and wall ( Outer Wall ) what r the differences.
The main point is how to mesh my 3D geometries as in my drawing I have followed the next:
1- Volume>cylinder> draw two cylinders then subtract them.
now how to set my mesh (64X16X48) to get 49152 cells only , As firstly when I was drawing by sweep faces the no. of cells was 98400 by using same point above ,
Heat Pipe is offline   Reply With Quote
Old   June 3, 2014, 01:05
CR-7
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 05:39
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
