[ICEM] CGNS output question
Old   June 16, 2014, 09:41
Unhappy CGNS output question
Ernesto
epc1 is on a distinguished road
Sorry to bother, I've got a question regarding cgns:
I've created a (volume) mesh by extruding a surface mesh along a curve. In order to do so I had to convert the 2D surface block to unstructured. The problem is that I want a structured cgns output. I've tried first converting the 2D surface mesh to multiblock but then I can not extrude the surface mesh.
The workaround would be to create the mesh by using a 3D block but I can not get a good quality mesh that way. My geometry is a 3D 90 degree pipe bend. I've completed a very similar tutorial (hexa mesh generation for an elbow part) but it is very difficult to set the correct associations in order to get a good quality mesh in my case.
What would be your suggestion to cope with this problem?
Thanks in advance
epc1 is offline   Reply With Quote
Old   June 18, 2014, 02:09
Crank-Shaft's Avatar
Ovi
Crank-Shaft is on a distinguished road
Please post some images so that everyone can visualise the problem and whether it is some obvious problem with the geometry or blocking.
Thanks.
Mechanical Engineering
Sydney, Australia
Crank-Shaft is offline   Reply With Quote
Old   June 18, 2014, 08:47
Ernesto
Edit: I already solved this problem. As I said before I needed a 3D block in order to export the mesh as a structured file. I've found the correct 3D blocking strategy.
Thanks
Changing Polynomial Properties of species from 8 to 16 coefficients Kenna OpenFOAM Programming & Development 1 November 20, 2013 03:44
CFD output question Moonlighter Main CFD Forum 2 December 21, 2009 14:29
Output transient file to csv Ben CFX 3 September 23, 2008 08:17
can "output control " output Nu in expression? prayskyer CFX 3 July 7, 2006 19:37
Help with DPM UDF for OUTPUT needed Zhengcai Ye FLUENT 0 January 5, 2004 16:58
