September 13, 2014, 21:46 |
Gambit meshing problem to following geometry
Ahmad Maulana
hi everyone, i'm having trouble meshing this geometry(picture attached). It is a part of a bigger geometry that i've divided into a several volumes.
In this volume, I've already mesh some faces and some edges. the meshing on the left side and upper side is from another volume. The face meshing on the back side, the obstruction inside the volume, and the edge meshing on the right side is my effort to create a structured volume mesh. however, when i tried to mesh volume. An error message appeared : unexpected problems during submapping of volume 207. Please, can anyone help me? |
October 21, 2014, 01:36 |
Maxime Perelli
Rep Power: 41 |
maybe is your volume 207 not suitable for hexa meshing.
I would try to copy this volume somewhere, and mesh it on the fly. If you cannot, then it is not suitable for hexa meshing, and you need to split it (I move your thread in the right subforum)
In memory of my friend Hervé: CFD engineer & freerider |
October 21, 2014, 01:49 |
Ahmad Maulana
thanks for the reply
i have already succeded in meshing the volume. apparently, the volume need to be divided more so it can be meshed. |
[ANSYS Meshing] Problem with meshing a complex Geometry (Hex) | fluent_beiyo | ANSYS Meshing & Geometry | 8 | April 26, 2014 04:55 |
Make geometry in Solidworks, meshing in Gambit | Dziyad | FLUENT | 0 | January 19, 2014 02:50 |
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry | mazhar1613 | ANSYS Meshing & Geometry | 1 | January 11, 2012 23:18 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
Problem meshing with Gambit | Adrian | FLUENT | 8 | October 7, 2008 08:39 |
