[ANSYS Meshing] Problem with meshing around the blade. |
March 21, 2016, 10:42 |
vijaykamesh
Rep Power: 10 |
I'm meshing the turbine blade in Y grid. I done the blocking(Please see pics). When i set the premesh, i realized something is wrong. the problem is edges around the blade. These edges are dissociated from the geometry(blade). My idea is this edges should create volume mesh in the domain but its meshing randomly on surface near the blade. when i saw with scan plane option, mesh around the blade it looks fine only at radial section (hydro foil, I created five hydro foils in the blade. please see pics) but i dont know how to fix this random mesh. Please help me, I'm stuck with this problem for two weeks. BLOCKING blocking_around_the_blade.jpg blocking_edge mesh shape.jpg Random mesh around the blade Premesh_collection.jpg Mesh with out around edges premesh_without_around edges.jpg scan plane scan_plane_top.jpg Last edited by vijaykamesh; March 22, 2016 at 05:12. |
March 22, 2016, 05:20 |
vijaykamesh
Rep Power: 10 |
Mesh at the radial section looks fine but below the radial section its not meshing properly. For an example, the scan plane section at tip and edges around the tip looks fine but below the tip section is not meshing properly. I dont know how to fix it. I need a help.
scan plane at tip scan_plane_tip.jpg scane plane below the tip. scan_plane_below _tip.jpg |
[ANSYS Meshing] Problem with meshing a complex Geometry (Hex) | fluent_beiyo | ANSYS Meshing & Geometry | 8 | April 26, 2014 04:55 |
[ICEM] Meshing problem in Formula one | Far | ANSYS Meshing & Geometry | 113 | April 23, 2013 12:36 |
[ICEM] problem with meshing in icem cfd | saurabhjoshi2011 | ANSYS Meshing & Geometry | 13 | March 12, 2013 11:27 |
[ICEM] Problem with meshing half NACA0009 in 3D | Eizo | ANSYS Meshing & Geometry | 30 | February 17, 2013 02:40 |
Question on blade meshing | Jeffrey | CFX | 0 | March 7, 2008 17:13 |
