November 25, 2016, 01:12 |
Ansys Meshing doubt
Rep Power: 9 |
I am creating a 3d model for a fluid flow in a rectangular channel in order to validate results from a paper (refer attached pic COMPARISON.jpg). Now, i am encountering problem in the contact regions between the fluid and solid as I cannot define biasing on the common edge as shown in the figure (conjugatefig.png). The mesh i require taken from a journal paper is also shown. kindly help as to how I can achieve the same kind of mesh. the basic problem is that i want to isloate the common edge to the fluid part so that i can achieve biasing only in the fluid region and not in the solid region. This way i can remove the skewness in the mesh and achieve straight orthogonal mesh as shown in the reference paper. Kindly help.Thank you. |
November 25, 2016, 07:34 |
Gwenael H.
Rep Power: 20 |
You need to slice your geometry in designmodeller before importing it into AM. To do so you can insert a plane and then use Create > Slice. You'll end up with smaller "blocks" that can easily be meshed and in your case you can then apply an identical bias for both fluid and solid geometry. |
December 1, 2016, 14:49 |
#3 | |
Rep Power: 9 |
December 2, 2016, 01:47 |
Gwenael H.
Rep Power: 20 |
If you want to have a non-conformal mesh of the fluid and solid and be able to mesh them separately (and also imposing a different bias between the two domains) you need need to have them in different parts in DM.
So if you split your fluid and solid geometry you then need to create a part for the fluid and another for the solid each one containing the respective subdivided domains. |
December 6, 2016, 16:47 |
Sarang Dalne
In DM, select the Fluid part in the tree and set the "Share Topology" option to None. In this way you don't have split the geometry but you will have separate fluid and solid edges/faces.
December 14, 2016, 22:28 |
Rep Power: 9 |
Yes but that creates a number of Contacts in Connections. Should I suppress them all? If i import like that into fluent, it createa interfaces. What should i do with that? Sorry for silly question. I have never worked with these contact sharing bodies. Thanks.
December 14, 2016, 22:29 |
#7 | |
Rep Power: 9 |
Sent from my XT1562 using CFD Online Forum mobile app |
[ANSYS Meshing] Mixed Order Meshing in ANSYS Meshing | oozcan | ANSYS Meshing & Geometry | 1 | August 1, 2020 06:48 |
[ANSYS Meshing] SHIP MESHING * using ansys WORKBENCH or ICEM CFD | Ctunramran | ANSYS Meshing & Geometry | 1 | February 23, 2016 07:06 |
Ansys airfoil meshing problem | Salah87 | ANSYS | 0 | August 13, 2015 02:49 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
Using ICEM CFD to repair/edit ANSYS Meshing | Kaaji1359 | ANSYS | 2 | July 30, 2013 10:28 |
