[ICEM] copy block to many small cyliders in a grid
Old   November 26, 2016, 06:34
Default copy block to many small cyliders in a grid
Quang Le Dang
SPH_CFD is on a distinguished road
Dear all
I have a problem that is a grid of many cylinders (same size but different positions). Do we have anyway to generate a block and then copy it to the others.
Project also requires to have all cylinders in the same *.msh file. The number of each grid is around 400 cylinders
Thank you in advance.
SPH_CFD is offline   Reply With Quote
Old   November 28, 2016, 07:59
Sebastian Engel
bluebase will become famous soon enough
Hello Quang,
Without any more information i can't figure out what is the best option for you.
You could try to copy the blocking in several subtopologies; you copy the resulting mesh the 400 times and live with interface meshes; or doing the hard labour, cutting by hand.
it might be a good idea anyways to write a script to automize the meshing.
Though, learning from the replay function and writing tcl code might take some time.
Start with creating using the replay/record feature and see what icem records.
Then take a quick tutorial on the tcl script language to get familiar with tcl for loops and calculations.
Search the forum for some sparse information on icem-scripts and have a look at the programming guide of icem. I learned the most from the script examples coming with icem, have a look in the installation folder.
With regards,
Sebastian
bluebase is offline   Reply With Quote
Old   November 28, 2016, 16:11
Quang Le Dang
Originally Posted by bluebase View Post
Hello Quang,
With regards,
Sebastian
Thank you Sebastian,
I try to copy block. However, it is very strange when I try to premesh and they only generate surface mesh.
My process as follow
1/ I have a grid of cylinders without connections between cylinders
2/ Generate a big block for all and associate to 1 specific cylinder
3/ copy that block to the other cylinders
I do not know why I do not have volume mesh
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 03:33
Generating elliptic grid around NACA SC2-0714 airfoil DA6righthand Main CFD Forum 20 November 3, 2015 07:50
how to make grid for "SST" like small Re method? wayne CFX 0 June 7, 2008 11:09
Does K-eps struggle with small grid sizes Nick FLUENT 1 May 2, 2007 06:55
Can a grid cell be too small? Danny FLUENT 0 August 16, 2005 09:19
