March 6, 2017, 04:39 |
named selection problem
Peeranat Tiranaprakij
Hi everyone.
I'm new in cfd. I am doing a simulation for a flow pass a truck that has a cyclist beside it. In geometry, I am using enclosure and subtract the truck and cyclist. I want to separate named selection between the truck and cyclist. I have tried to hide enclosure faces but i cant select each of the truck and cyclist faces because there are so many faces. So how can i create a named select each of them. Here is my geometry. http://imgur.com/a/tOdvl Thank you. |
March 9, 2017, 05:53 |
Paritosh Vasava
Rep Power: 22 |
The simplest way would be to select with a rectangular region. On the top ribbon there should be an icon with an arrow and a red dot. The options are available in the drop-down menu right next to this icon.
March 9, 2017, 06:20 |
Thanks a lot vasava.
This really helps me. |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
[ANSYS Meshing] Script Connection Friction | arpeedesign | ANSYS Meshing & Geometry | 4 | April 11, 2019 08:17 |
[ANSYS Meshing] Interlocking two body named selection | oozcan | ANSYS Meshing & Geometry | 6 | July 20, 2016 02:38 |
Named Selection Mesh View | mgpaul | CFD Freelancers | 3 | October 28, 2015 08:56 |
[DesignModeler] Big problem with named selections | lacaillg | ANSYS Meshing & Geometry | 2 | March 13, 2013 06:38 |
