[ANSYS Meshing] named selection problem
Old   March 6, 2017, 04:39
Default named selection problem
Peeranat Tiranaprakij
film1406 is on a distinguished road
Hi everyone.
I'm new in cfd.
I am doing a simulation for a flow pass a truck that has a cyclist beside it.
In geometry, I am using enclosure and subtract the truck and cyclist.
I want to separate named selection between the truck and cyclist.
I have tried to hide enclosure faces but i cant select each of the truck and cyclist faces because there are so many faces.
So how can i create a named select each of them.
Here is my geometry.
http://imgur.com/a/tOdvl
Thank you.
film1406 is offline   Reply With Quote
Old   March 9, 2017, 05:53
Paritosh Vasava
vasava will become famous soon enough
The simplest way would be to select with a rectangular region. On the top ribbon there should be an icon with an arrow and a red dot. The options are available in the drop-down menu right next to this icon.
vasava is offline   Reply With Quote
Old   March 9, 2017, 06:20
Thanks a lot vasava.
This really helps me.
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
[ANSYS Meshing] Script Connection Friction arpeedesign ANSYS Meshing & Geometry 4 April 11, 2019 08:17
[ANSYS Meshing] Interlocking two body named selection oozcan ANSYS Meshing & Geometry 6 July 20, 2016 02:38
Named Selection Mesh View mgpaul CFD Freelancers 3 October 28, 2015 08:56
[DesignModeler] Big problem with named selections lacaillg ANSYS Meshing & Geometry 2 March 13, 2013 06:38
