June 3, 2017, 07:23 |
Periodicity in ICEM
Dim. G
Rep Power: 8 |
Hello everybody,
I am trying to create periodicity for a simple geometry in icem. First of all, I want the periodic walls to be the surfaces that are created from the numbers ( 25 26 42 41) and (21 22 38 37). The geometry will be rotated in the Z axis for 360 degrees. My question is simple. Which vertices shall I choose for the periodicity? |
June 6, 2017, 06:25 |
Sebastian Engel
Rep Power: 20 |
Hi gdimitirs,
select every vertices with the respective twin in the other periodic boundary. Assuming, you have a segment of a cylinder you would connect 21 and 25, 41 and 37, and so on. with regards, Sebastian |
[ICEM] How define periodicity correctly in ICEM | FJSJ | ANSYS Meshing & Geometry | 18 | January 11, 2023 11:07 |
[ANSYS Meshing] ICEM: Periodicity errors after importing mesh in Fluent | pisykl | ANSYS Meshing & Geometry | 4 | June 28, 2016 21:10 |
[ANSYS Meshing] Periodicity problems in icem | zeeshu | ANSYS Meshing & Geometry | 0 | April 17, 2016 20:59 |
[ICEM] ICEM periodicity specification | robboflea | ANSYS Meshing & Geometry | 18 | November 11, 2014 14:51 |
[ICEM] Periodicity Setting ICEM for CFX | Julien | ANSYS Meshing & Geometry | 0 | January 25, 2014 09:54 |
