[ICEM] Need help---ICEM multi-block meshing
Old   March 31, 2018, 11:50
Default Need help---ICEM multi-block meshing
Shaoze
sminder is on a distinguished road
Hello everyone,
I'm working on ICEM multi-block meshing for a complex wing-body aircraft model. I really need some help as none of my colleges has ever used multi-block meshing. I'd be much appreciated if anyone can give me a hint.
My model is just a normal aircraft except there is a blowing slot on the trailing edge, and there is a chamber inside the wing. I prefer to use multi-block meshing which gives a mapped surface mesh and unstructured volume mesh to fill up the far field space, in the meantime I want the mesh inside the chamber to be a structured hexa volume mesh. That means there will be two types of volume mesh, inside the blowing chamber is structured, and outside space is unstructured.
The problem is how can I divide the volume mesh into two different types? I have tried to draw an interface on the blowing slot, then using multi-block meshing to generate mapped surface with tetra volume, and then using 'extrude face' to generate a block inside the blowing chamber. Everything went well until I extruded the new block inside the chamber, the tetra mesh failed...
Does anyone have an idea on how to use multi-block mesh properly in this case?
Many thanks!
Shaoze
sminder is offline   Reply With Quote
icem multi block mesh
[ANSYS Meshing] SHIP MESHING * using ansys WORKBENCH or ICEM CFD Ctunramran ANSYS Meshing & Geometry 1 February 23, 2016 07:06
[ICEM] Meshing Chamfered Cube Block mhmtblt ANSYS Meshing & Geometry 0 December 10, 2015 07:22
[blockMesh] Mixer mesh - negative volume problem jadtwo OpenFOAM Meshing & Mesh Conversion 2 November 6, 2014 16:37
Help me to choose between Ansys Meshing, Fluent Meshing or ICEM ? pipolaki ANSYS 0 December 6, 2013 08:12
Using ICEM CFD to repair/edit ANSYS Meshing Kaaji1359 ANSYS 2 July 30, 2013 10:28
