[ICEM] why could i use the" link edge"function like this
Old   October 8, 2019, 10:52
Default why could i use the" link edge"function like this
JiangSU
steins is on a distinguished road
I learn the airfoil meshing on https://www.youtube.com/watch?v=7GLYQwCsc8A
i want to make a boundary layer,in the video ,the author firstly use ogrid to create a around block, then he use the link edge to make the later edge parallel to the edge he had edit before (10:05)
but when i want to do this ,the linked edge coincide to the edge before,i don`t know where is wrong.
could anyone help me?Thanks a lot!
steins is offline   Reply With Quote
Old   October 8, 2019, 11:22
Sebastian Engel
bluebase will become famous soon enough
Hi Jiang,
you have set the (linking) factor to 3.0.
In the video it's set to 1.0.
This factor is a scaling factor for the target edge shape with respect to the source shape (as the manual states).
1.0 means that the target mesh approximately looks like the source.
<1 means the shape is only loosely coupled ("only a slight bend")
It seems larger than 1 means the target should increasingly become the source shape.
Best regards,
Sebastian
bluebase is offline   Reply With Quote
Old   October 9, 2019, 10:11
JiangSU
Hey Sebastian
Thanks so much for your reply,that may not be the main point,even if i set the factor to 1.0, the target edge still coincide to the target edge but not parallel to it.
Finally i create the vertices and move it one to one.
Best regard
Jiang
LINK errors compiling udf marco91 Fluent UDF and Scheme Programming 0 December 5, 2018 06:13
Link Coolprop to Fluent UDF ilfrance90 Fluent UDF and Scheme Programming 0 March 8, 2018 06:14
[GAMBIT] Link Face Meshes + Size Function sasizza ANSYS Meshing & Geometry 1 April 14, 2015 09:01
[GAMBIT] Error message: Cannot link faces due to all loops of edges not being specified Aerogirl ANSYS Meshing & Geometry 4 February 19, 2012 08:21
ReleaseNotes13 website link problem maka OpenFOAM 2 November 22, 2006 04:32
