[ICEM] No "apply" button" on Trying to rotate a block |
March 21, 2020, 20:44 |
Hazem
Rep Power: 6 |
Dear members,
I know this may sound simple but I've been stuck here.. I'm trying to create a hex mesh for a 3 blade wind turbine. Using slicing I made a block surrounding one blade (since the blade is horizontal) and saved it as a part in the tree "BLADE_1" Now I need the two other blades to have the same block, I'm trying to use rotate block, I selected the block and entered all the options and can't find the apply button and the middle click doesn't do it also. A Any help Regards, Hazem |
March 22, 2020, 04:14 |
M
Rep Power: 12 |
Would it not be easier to mesh only 1/3 of the geometry and make rotational copies of the mesh instead of the blocking? I have not done your approach yet but I guess you have to re-assign all edge associations even if you get the block pattern done?
March 22, 2020, 05:41 |
Thank you for your reply
Hazem
Rep Power: 6 |
Dear sir,
Your reply is appreciated! Your suggestion sounds easier, but are you aware that 1/3 of the mesh would mean 1 blade plus 1/3 of the inner domain's and the outer domain's volumes? If yes, then could you explain how I can do that? |
March 22, 2020, 06:12 |
M
Rep Power: 12 |
You would cut your geometry in the CAD tool you use (DesignModeler, SpaceClaim or similar) so you only have 1/3 of it. Then just do the blocking how you did already. Create a mesh from it -> now you have 1/3 of it.
Then in the mesh tools there are options to make rotational or translational copies of the part. Make sure to merge coincident elements when doing this. |
March 22, 2020, 06:49 |
Hazem
Rep Power: 6 |
This is a good idea thank you for it!
But can I also make the cutting inside the ICEM? Because I imported only the turbine rotor from design modular and there was a problem in importing the domain cylinders which I drew on ICEM If not possible to slice on ICEM, could I import one blade and draw 1/3 of a cylinder in ICEM? |
[blockMesh] Velocity,Pressure locked in Blocks | Tobi94 | OpenFOAM Meshing & Mesh Conversion | 2 | December 31, 2019 08:27 |
[ICEM] Rotated the Blade and was unable to rotate the respective mesh block | juzer_700 | ANSYS Meshing & Geometry | 2 | July 30, 2015 04:45 |
[blockMesh] Mixer mesh - negative volume problem | jadtwo | OpenFOAM Meshing & Mesh Conversion | 2 | November 6, 2014 16:37 |
foamLog not solving for Ux, Uy, Uz | aerospain | OpenFOAM Post-Processing | 5 | April 18, 2012 10:01 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
