[ANSYS Meshing] Skewness and Orthogonal quality inspection
Old   July 7, 2020, 13:47
Default Skewness and Orthogonal quality inspection
Raj
Rajkool is on a distinguished road
Hello all,
I have a complex body with more than 300 parts. I have given mesh based on body shapes.
The mesh is successful. I just want to know that, should we consider only average value for skewness and orthogonal quality or we should also take Min value of the node into account too?
(PS: If I don't make any sense in my question please look into attached images)
Thanks in advance,
Raj
Rajkool is offline   Reply With Quote
Old   July 7, 2020, 15:53
Nico
NicoKlein is on a distinguished road
Good afternoon Raj,
normally the Min and Max values should be your concern, since these are the elements who can be the reason for a divergence of the solution. A target value for the skewness should be < 0.25 but everything below 0.9 is acceptable. For the orthogonal quality, I am not 100% sure.
NicoKlein is offline   Reply With Quote
Old   July 7, 2020, 17:39
Raj
As you can see my images. I have some nodes with very low skewness and very low OQ values. But, the average seems to be fine.
What would you suggest me to do now?
Old   July 21, 2020, 01:48
Guvennergiz's Avatar
Guven Nergiz
Guvennergiz is on a distinguished road
Hello Rajkool,
Please check the figure below for min. ortho and max. skewness.
Best regards,
Güven
Guvennergiz is offline   Reply With Quote
[ICEM] Minimum Orthogonal Quality when imported to FLUENT pchoopanya ANSYS Meshing & Geometry 2 November 6, 2020 23:29
[Other] How to find mesh skewness, orthogonal quality, and other values for mesh quality Bran ANSYS Meshing & Geometry 1 July 28, 2019 05:25
Deforming Mesh Orthogonal Quality Improvement siaam FLUENT 0 December 18, 2018 06:35
[ICEM] Mesh quality criteria in ICEM Chander ANSYS Meshing & Geometry 13 September 5, 2017 08:52
[ANSYS Meshing] Improving orthogonal skewness Allen fernandes ANSYS Meshing & Geometry 0 January 25, 2017 05:26
