[ANSYS Meshing] how to generate prism mesh in tube-shell exchanger?
Old   February 22, 2022, 23:06
Default how to generate prism mesh in tube-shell exchanger?
qihongming
qihongming is on a distinguished road
how to use ansys meshing to generate prism mesh in tube-shell exchanger?
following picture is generated by ansa.it is done by my friend.
qihongming is offline   Reply With Quote
Old   February 23, 2022, 04:35
Gert-Jan
Gert-Jan will become famous soon enough
Use your RMB (Right Mouse Button) on Mesh, and select inflation. There, first select the volume and secondly the walls you want to inflate.
This is a very basic question. Did you do any tutorial?
Gert-Jan is offline   Reply With Quote
Old   February 23, 2022, 19:50
qihongming
I'm sorry; maybe I didn't describe it clearly.
First, I emphasis the volume mesh is prism, inflation is hex. I want to use Mutizone method, and found its failure
Old   February 24, 2022, 12:33
Void_CFD-user
Indra is on a distinguished road
Wouldn't it be better to have hex in the volume and for boundary layer, either hex or prism?
Given the complexity and size of your model, you would be better of using Poly-hexcore meshing in Fluent meshing, you are spending too much of you time in ansys meshing.
But generally, a combination of inflation and multi-zone should help you make this mesh. But again, it would be time taking and complex.
Indra is offline   Reply With Quote
Old   February 24, 2022, 13:51
Gert-Jan
I think it should be possible using Multizone, but your geometry should be very clean. The mesher prefers sweepable bodies. It you don't have them, then you'll have a hard time.
Also, dedicated meshers like ANSA can generate better meshes than the general purpose mesher in Workbench.
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent medogalal FLUENT 3 December 30, 2015 04:28
Shell and tube heat exchanger modeling hmasenger CFX 3 January 20, 2014 03:36
shell and tube heat exchanger samidabest FLUENT 0 January 8, 2013 03:26
