[ANSYS Meshing] how to generate prism mesh in tube-shell exchanger? |
February 22, 2022, 23:06 |
qihongming
Rep Power: 17 |
how to use ansys meshing to generate prism mesh in tube-shell exchanger?
following picture is generated by ansa.it is done by my friend. |
February 23, 2022, 04:35 |
Gert-Jan
Rep Power: 27 |
Use your RMB (Right Mouse Button) on Mesh, and select inflation. There, first select the volume and secondly the walls you want to inflate.
This is a very basic question. Did you do any tutorial? |
February 23, 2022, 19:50 |
qihongming
Rep Power: 17 |
I'm sorry; maybe I didn't describe it clearly.
First, I emphasis the volume mesh is prism, inflation is hex. I want to use Mutizone method, and found its failure |
February 24, 2022, 12:33 |
#4 | |
Void_CFD-user
Rep Power: 4 |
Given the complexity and size of your model, you would be better of using Poly-hexcore meshing in Fluent meshing, you are spending too much of you time in ansys meshing. But generally, a combination of inflation and multi-zone should help you make this mesh. But again, it would be time taking and complex. |
February 24, 2022, 13:51 |
Gert-Jan
Rep Power: 27 |
I think it should be possible using Multizone, but your geometry should be very clean. The mesher prefers sweepable bodies. It you don't have them, then you'll have a hard time.
Also, dedicated meshers like ANSA can generate better meshes than the general purpose mesher in Workbench. |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent | medogalal | FLUENT | 3 | December 30, 2015 04:28 |
Shell and tube heat exchanger modeling | hmasenger | CFX | 3 | January 20, 2014 03:36 |
shell and tube heat exchanger | samidabest | FLUENT | 0 | January 8, 2013 03:26 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
