[ANSYS Meshing] Applying tubular face meshing to half cyilnders
Old   June 26, 2022, 18:25
Default Applying tubular face meshing to half cyilnders
Sean Small
seansmall is on a distinguished road
I am currently meshing a very thin cylinder using swept method, edge sizing, and a face meshing with 100 internal divisions. When I try to apply this same mesh to a half cylinder (to use symmetry), there is no way to do internal divisions through face meshing. Edge sizing does not seem to work either.
Any Suggestions?
seansmall is offline   Reply With Quote
Old   June 28, 2022, 03:37
siw
Stuart
siw will become famous soon enough
To quote the Ansys Meshing User Guide help/wb_msh/msh_Basic_Map_Face_Mesh.html: For the Definition> Internal Number of Divisions control, specify the number of divisions across annular regions or seamless cylinders. Hence, not possible for a half cylinder.
Can you just use edge sizings to set the number of divisions and behavior to Hard for the Sweep Method (which is default if the geometry is suitable). Or give the MultiZone Method a try.
I cannot guess what you are simulating that requires so many elements through such a thin wall at such a high aspect ratio.
siw is offline   Reply With Quote
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points Simurgh OpenFOAM Meshing & Mesh Conversion 4 August 25, 2023 07:58
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Problem with 'Mapped Face Meshing' RobertW FLUENT 0 November 19, 2016 15:39
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
Error message: 8 face(s) not in face lists of adjacent cells jyoung79 FLUENT 0 November 10, 2012 16:09
