July 23, 2022, 05:35 |
a wall part inside the fluid domain
ENIMA
Rep Power: 4 |
hi friends,
i'm working on a geometry in ICEM for Cfx Pre flow simulation, the calculation domain is fluid , it has a rectangular form and extruded for 3°. inside the domain the duct of the flow, so i'm struggling with this duct to consider it in the domain as a wall part , i have tried some tips but it doesn't work , the part does not appear in cfx pre i hope that someone can help to fix this problem greetings |
July 23, 2022, 07:03 |
Gert-Jan
Rep Power: 27 |
Your text is very unclear. I need to read it 5 times to understand it. And without pictuures of your geometry it is even more difficult to understand. Please be more precise next time.
But it looks like you work in ICEM and have a fluid volume with a duct as an obstacle and this duct does not appear in Pre. Does this duct have any volume or is it a sheet (thin surface)? Please show a picture of your geometry......... |
July 25, 2022, 11:24 |
answer
#3 | |
ENIMA
Rep Power: 4 |
the duct is a sheet (a thin surface) i have attached a picture of the geometry i hope that every thing is clear thank you for your help |
July 25, 2022, 17:13 |
Gert-Jan
Rep Power: 27 |
Provided you make a tet/prism-mesh, you should go to Mesh > Part Mesh Setup.
There, on the right hand side, you should tell ICEM that your Geometrical Surface is an Internal wall, or a Split wall. The difference is that the Internal wall will have the same mesh on both sides of the internal wall (conformal), the split mesh will result in different mesh. As a consequence, the Internal wall will give you the option in Pre to define it as a wall or as an interface, i.e. no wall. The split wall can only be used as wall. It has therefore less flexibility, so I would recommend internal wall. |
chtMultiRegionFoam: two fluid regions separated by a thin, conducting wall | JayDeeUU | OpenFOAM Pre-Processing | 16 | July 22, 2021 21:17 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
How to insert a heat source only in the fluid part of a fluid-air domain? | milabvieira | CFX | 4 | August 21, 2015 07:09 |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 11:27 |
