[ANSYS Meshing] mesh is not properly mapped on connected gaces |
March 18, 2024, 08:05 |
Rep Power: 7 |
Hi, I have created 3D hexahedral mesh. however there is some problem in mapping mesh on one face and realted. Can anyone please let me know what is the issue? Thank you! inlet and symmetric parts.jpg front view.jpg
March 19, 2024, 15:09 |
Erik
Rep Power: 23 |
Looks like you have separate bodies. You should "create part" in design modeler, or "share topology" in Spaceclaim so that this is a multibody part with shared nodes and a conformal mesh across the interfaces. Without this, you are just meshing separate bodies with no regard for each other, and each line or face between then will actually be two lines or faces, one for each body.
March 24, 2024, 05:59 |
#3 | |
Rep Power: 7 |
1. I have named the faces and upon reading the file in fluent. there are so many interfaces and airfoil is not displayed. 2. if I suppress the interfaces then there is no interior displayed in display window. However, the geometry parts are displayed. can you please elaborate. what is the mistake again. Thank you |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 12:38 |
[snappyHexMesh] snappyHexMesh stuck when snap is turned on | yukuns | OpenFOAM Meshing & Mesh Conversion | 3 | February 2, 2021 13:05 |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
[mesh manipulation] CreateBaffles generates distorted mesh | Andrea_85 | OpenFOAM Meshing & Mesh Conversion | 0 | May 24, 2019 04:36 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
