[ICEM] v10 and v11 compatibility problem
Old   August 2, 2010, 05:39
Default v10 and v11 compatibility problem
Sofia
Sofia is on a distinguished road
Hi everybody!
I'm currently using ICEM CFD v10 on a rae2822 airfoil. I'm using a geometry imported from ICEM v11. I have imported it by using File>>Import Geometry>>STEP/IGESY>> my file *.stp. I had to select "Use version 5.1 step translator" to keep my geometrical scaling. But it seems that i have compatibility errors (i made the same work on a v11).
Does anyone knows how i can do a proper importation of a v11 geometry on a v10 Icem please??
Sofia is offline   Reply With Quote
Old   August 3, 2010, 22:00
Default Save Geometry as version
PSYMN's Avatar
Simon Pereira
Don't convert back to IGES... If you already have the ICEM CFD Version 11 Tetin file (*.tin), Just load that file in V11 and then go to File (menu) => Geometry => Save Geometry as version => Version 10 File...
But just out of curiosity, why are you going back to version 10?
Simon
Old   August 4, 2010, 07:58
Sofia
Thank you!!
I have the v10 on my computer but the geometry I received was a v11 one!
Old   August 4, 2010, 21:36
Default 10.0
PSYMN's Avatar
Simon Pereira
So are you set then?
There is a text editor way you can fix the files without having 11.0 on hand to fix it for you. You just need to delete a line, I don't quite recall the details since I havn't needed 10.0 for a long time, but can try to dig it up if you need it. Send me the error message you got since that will help me remember.
I still recommend updating to 12.1.
Simon
Old   August 5, 2010, 07:29
Sofia
Yes, the problem is solved with the saving procedure! Thank you very much Simon!
ICEM hexa mesh built with v10 deformed in v11 (degenerated edges) cfxicem ANSYS Meshing & Geometry 1 October 14, 2009 15:06
