Home > Forums > Software User Forums > ANSYS
Error:Hydrodynamic Diffraction (A4): ILLEGAL CONNECTIVITY.
Old   November 9, 2015, 15:08
Default Error:Hydrodynamic Diffraction (A4): ILLEGAL CONNECTIVITY.
Krishna
krishna_ocean is on a distinguished road
Hello Everyone,
This post is related to an error message while trying to study the motion response characteristics of a simple floating body using Ansys-AQWA as part of my research work. When I try to study hydrodynamic diffraction of the floating body I am encountering with error message as follows:
Error! Hydrodynamic Diffraction (A4): Solve aborted!
Error! Hydrodynamic Diffraction (A4): TERMINATED WITH ERRORS
Error! Hydrodynamic Diffraction (A4): ILLEGAL CONNECTIVITY. Element 60 is joined to element 153 and element 671
Informational Hydrodynamic Diffraction (A4): Mass/displaced mass are significantly different for structure 1 . Difference = -1.0%
Warning! Hydrodynamic Diffraction (A4): 372 MODELLING RULE #1 VIOLATIONS IGNORED BY GOON OPTION
Hydrostatics solve solution is working without solution getting aborted.
Can anyone please help me to figure out what could be the possible error? Is it something related to meshing of the model?
I am new to this software and if anyone could guide me with their knowledge it will be of great help. I hope someone would have encountered with the same error before but I couldn't find any thread giving solution for the same. Awaiting for a helpful reply.
Thanks in advance.
krishna_ocean is offline   Reply With Quote
Old   November 23, 2015, 05:16
AQWA is on a distinguished road
Hello everyone,
Has anyone else experienced this problem?
Did you sort this out?
I have modified everything, started my model again from scratch but nothing worked...
Any idea?
Thank you very much for your time
All the best,
AQWA is offline   Reply With Quote
Old   August 6, 2022, 17:50
No Selection
vishalkuvar07 is on a distinguished road
Try to change the value in connection tolerance.
Mesh-->waterline node generation --> connection tolernce
vishalkuvar07 is offline   Reply With Quote
[Gmsh] Cell to node connectivity after 'gmshToFoam' Jibran OpenFOAM Meshing & Mesh Conversion 1 June 8, 2015 09:09
meshing of a compound volume in GMSH shawn3531 OpenFOAM 4 March 12, 2015 10:45
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
illegal use of this type as an expression abir Fluent UDF and Scheme Programming 0 January 20, 2013 10:27
SegFault due to illegal readwrites msg30 OpenFOAM Bugs 4 December 12, 2007 12:44
