Ansys
Old   November 27, 2020, 10:49
Default Ansys
karan
karan123 is on a distinguished road
The issue occurred in the cross-section process. Since you don't pick the correct face as a limit. On the off chance that your model contains 3 bodies, and you need to pick and name a face in one of the bodies, you would be wise to conceal the other two bodies so you don't pick an inappropriate face. The stream limit id is an inappropriate face you picked. Return to your cross-section programming and rechoose the face, at that point there would be no issue.
geforce pour pc
karan123 is offline   Reply With Quote
Running Ansys in BAtch Mode kuleuvenstudent ANSYS 1 October 18, 2017 12:11
[ANSYS Meshing] ANSYS mesh - I was surprised... assafwei ANSYS Meshing & Geometry 0 September 4, 2014 12:17
Ansys HPC licensing policy assafwei ANSYS 0 June 29, 2014 16:00
Using ICEM CFD to repair/edit ANSYS Meshing Kaaji1359 ANSYS 2 July 30, 2013 10:28
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 01:10
