Home > Forums > Software User Forums > ANSYS
how to connect two separate outlets
Like Tree1Likes
  • 1 Post By Gert-Jan
Old   August 31, 2021, 06:11
Default how to connect two separate outlets
Martin_Sz's Avatar
Marcin
Martin_Sz is on a distinguished road
Hello Im facing with problem
I have multiple inlets and outlet. The are separate geometrical. I need to coonect two outlets to make flow from them.
Its good to make interface on these outlets or something else??
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD)
https://howtooansys.blogspot.com/
Martin_Sz is offline   Reply With Quote
Old   November 10, 2021, 04:48
Default Good question
Onlineman is on a distinguished road
Yes, this is an actual question for me now!
Onlineman is offline   Reply With Quote
Old   November 13, 2021, 06:03
Gert-Jan
Gert-Jan will become famous soon enough
If you can get away with same massflow on inlet-outlet-combination and same massflow average Temperature and/or concentrations, then it is possible to do this in CFX using expressions. E.g., if the fluid entering through inlet 1 equals the conditions from Outlet1, then you can write:
MassFlowIn1=massFlow()@Outlet1
TempIn1 = massFlowAve(Temperature)@Outlet1
Remember, this ignores any profile information, which is probably not so important if the inlet and outlet are far away anyway.
arnie333 likes this.
Gert-Jan is offline   Reply With Quote
mpt_connect: errorThe fl process could not be started. MPI Application rank 0 exited tjZDH FLUENT 3 November 28, 2021 14:30
How to connect values between two separate walls lrodrigues FLUENT 3 January 28, 2019 10:36
Error in compute process - No Active Application yetlyg FLUENT 8 October 27, 2018 22:30
error: connect failed destroy FLUENT 7 March 18, 2018 14:59
connect failed with errno%3d113 wedsall OpenFOAM Running, Solving & CFD 2 November 3, 2008 04:17
