Home > Forums > Software User Forums > ANSYS
Retrieving strain energy from COMBIN39 nonlinear spring element
Old   August 15, 2022, 12:49
Default Retrieving strain energy from COMBIN39 nonlinear spring element
Johannes Schneider
Kopfgeburt is on a distinguished road
I use nonlinear springs type COMBIN39 to model contact of a loaded cantilever beam (BEAM188) with stiff ground.
The COMBIN39 elements are evenly distributed along the beam, representing a continous bedding. As long as there is no beam-ground contact, the stiffness of these elements is very small k0 (zero stiffness is not allowed). Initially beam and ground are separated by a distance w*. As soon as the beam touches the ground (w >= w*), there is a change in stiffness k1 >> k0.
I can model this nonlinear behaviour with a set of real constants:
r,3,0,0,w*,k0,w*+1,k1
I want to read the total strain energy (SENE). To do so i use element-tables which i then sum up:
esel,s,ename,,188
etable,sene188,sene
esel,s,ename,,39
etable,sene39,sene
allsel
ssum
The output for sene188 looks fine, but for sene39 it is always zero.
From the total potential for a linear spring i know that U = 1/2 k w^2 and thus in this case U = 1/2 k1 (w-w*)^2. From an approximate calculation by hand i know that this is unequal zero.
Does anyone know how to retrieve the strain energy from a COMBIN39 element?
Kopfgeburt is offline   Reply With Quote
Old   August 18, 2022, 08:27
Default No strain energy available for COMBIN39
Johannes Schneider
In table 14.4: Exceptions for Element Energies from the theory reference manual the COMBIN39 is listed and thus no energy is available for this element type.
For this simulation a COMBIN40 element might be suitable.
ansys, combin39, strain energy
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM Ancioi OpenFOAM Meshing & Mesh Conversion 17 January 8, 2019 23:50
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 05:29
Two way Fsi Problem- Non linear problem kmgraju CFX 4 April 28, 2015 11:15
autoPatch error, mesh quality related...? Alexvader OpenFOAM 0 October 6, 2011 17:57
