solid- solid interface
Old   September 1, 2004, 05:48
Default solid- solid interface
Peter
Hi everybody,
I am trying to calculate a thermal problem with convective heat transfer and conduction between two solids. Do I have to define a boundary condition between the solids- as wall-conductive for example? What is assumed if I don't define a boundary between the interface solid-solid? The solution doesn't converge for the enth of the solids?
Thanks
Old   September 9, 2004, 09:46
Default Re: solid- solid interface
jing
for such a case, if you use the conjugate heat transfer approach, you don't need to define a boundary on the solid-solid interface. Otherweise, yes.
heat resistance on solid-solid interface Bela CFX 8 October 25, 2022 16:02
Thermal resistance at the solid-solid interface Andrew Siemens 0 April 18, 2006 10:55
solid-solid interface greg FLUENT 0 October 11, 2005 10:16
BC at the interface of the fluid and solid manohar Siemens 3 April 8, 2005 11:34
solid-solid interface Mohamed CFX 2 March 8, 2005 03:05
