Star Design to Star-CD(Prostar)
Old   October 27, 2004, 16:50
Default Star Design to Star-CD(Prostar)
AB
Hello All,
How can we export or transfer a model from star design to star-CD/prostar? Do we need to mesh or grid the model in star design before we export it or we can mesh it later in prostar after we have imported frm star design.
Thanks in advance,
AB
Old   October 28, 2004, 05:01
Default Re: Star Design to Star-CD(Prostar)
4xF
a) You have to mesh the model in STAR-Design b) You have to start a run with 0 iterations, so that the model file is written. Use an additional input file containing the pro-Star command: ITER,0
Old   October 28, 2004, 05:42
Jörn Beilke
It is also possible to export the geometrie in *.ezs Format and do the surface meshing in pro-surf.
Old   October 28, 2004, 07:18
Leo
If you have a newer version of STAR-Design, you don't need to run for one iteration. Once you have a volume mesh you can choose "Solver preprocessing" from the Solver menu.
Old   October 28, 2004, 11:11
thomas
in StarDesign (expert modus):
solve,postprocess !by this command .dbs-file will be saved in the stardesign-directory
in Pro-AM:
dbase,open fromStarDesign.dbs ! open .dbs-file
dbase,list
Old   October 28, 2004, 12:21
AB
Thanks a lot for all the tips and tricks for exporting file from star design to star-CD (prostar) but when I follow all the methods, I am getting this error all the time... what is the reason for this, though I am able to export simple models but not my own model which comes up with this error..
ammbatch30421.exe- Application error
the instruction at "0x00739c29" referenced memory at "0x09248ea8". the memory could not be "read".
click on OK to terminate the program
click on CANCEL to debug the program
how to export a mesh from star design to star cd aounallah Siemens 4 March 6, 2009 06:22
from prostar to star-desing/post cirilo Siemens 1 July 13, 2006 02:33
Solve Sudoku using prostar/star v4: Excellent!!!! Algo-dorak Siemens 2 May 28, 2006 11:38
iges-prosurf-proam-prostar-star elvis Siemens 6 October 17, 2005 04:35
