CFD analysis on regenerative pump using ANSYS CFXs |
July 14, 2014, 08:10 |
Rep Power: 12 |
Dear friends, I am conducting a CFD analysis on regenerative pump using ANSYS CFX (MRF approach). Please see the model attached. http://s9.postimg.org/cugg0fogv/image.jpg
The model consists of 3 regions- inlet domain ,impeller domain and outlet domain. Impeller is rotating at 2800 rpm. At inlet , total pressure =101953pa and at outlet, mass flow rate =0.76kg/s . The pump is expected to produce 25 m head.But from analysis it is found that ,pressure at the outlet of the pump is negative. See the pressure distribution> http://postimg.org/image/7t53erj3j/ Can anyone help me with this problem... Thanks in advance.. |
July 14, 2014, 18:12 |
Rep Power: 143 |
April 6, 2016, 01:59 |
Rokson K Mathew
Rep Power: 10 |
Hi Rakesh!
I am facing the same issue. Was it resolved in your case? if yes, then please do help. |
April 6, 2016, 12:17 |
You will need to show details of cfd domain geometry, boundary conditions and interface modelings.
Using ICEM CFD to repair/edit ANSYS Meshing | Kaaji1359 | ANSYS | 2 | July 30, 2013 10:28 |
FDM vs FVM vs FEM in CFD analysis | ck5285 | FLOW-3D | 1 | September 1, 2009 10:51 |
Will the ANSYS - FLUENT- CFX kill freedom of CFD? | Ben | Main CFD Forum | 17 | September 20, 2006 03:36 |
Free UK seminars: ANSYS CFD software | Gavin Butcher | CFX | 0 | November 23, 2004 09:13 |
CFD for fans & blower housings | David Carroll | Main CFD Forum | 8 | August 24, 2000 17:25 |
