flow rate at outlet
Old   March 13, 2016, 09:12
Default flow rate at outlet
yaseen
yaseen wsu is on a distinguished road
hello every one
I simulated free surface flow in hydraulic structure after simulation in CFX post I want to know my simulation was reached to steady state, so I need to compute discharge (flow rate) at outlet in order to compared with inlet, how can do this?
thanks
yaseen wsu is offline   Reply With Quote
Old   March 14, 2016, 05:28
Maxim
-Maxim- is on a distinguished road
create an expression with a ratio between those two, set as monitor variable and check that during the run.
I think you can also work that into a stop criteria if you want.
-Maxim- is offline   Reply With Quote
Old   March 14, 2016, 06:40
yaseen
thanks for you reply, setting a monitor variable before run?, what does that mean stop criteria? how to create ...... thanks
Old   March 14, 2016, 07:01
Maxim
yes.
Please read the documentation. It is clearly describing how to introduce a new expression/variable as a new monitor for solver manager.
You could also set a conservation target (usually to 1%). Through a quick google search I found this for you. Those slides talk about conservation target and stopping criteria ('interrupt control').
Plotting mass flow rate at outlet for transient simulation Rakib Fluent Multiphase 4 September 5, 2015 23:46
DPM total mass flow rate yow FLUENT 0 July 17, 2015 12:01
Problems in pressure when using mass flow rate outlet rafiktharwat CFX 11 January 2, 2014 17:21
Fixed Flow rate and outlet Continuity Problem mrshb4 OpenFOAM 1 March 10, 2012 14:32
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
